Backhoe John Deere 302A - goes in reverse, but will not go in forward gear
   / John Deere 302A - goes in reverse, but will not go in forward gear #1
MyRivers
Texas
John Deere 302A
Hello,
I'm a newbie and looking for information for my brother. He is working on his John Deere 302A backhoe, which is from the 70's, I believe. He said the problem is that he can do everything in reverse, but nothing in forward, and it's getting hard to get any work done that way. He changed out both of the hydraulic filters, but nothing changed, so he's having a bad day.
He said it has been running fine in forward, but could have been running a little weak in forward, after looking back at the problem. It happened suddenly. If anyone out there has any ideas, please let me hear them. They would be much appreciated.
Thank you!!
   / John Deere 302A - goes in reverse, but will not go in forward gear #2
Check linkage to be sure control valve is shifting into fwd. Also check pressure on RH side on control valve. Pressure should be in the 165# range.
City of Tampa (1611) VIN: 1FTMF1CM1EFB40793, **Title MUST be transferred into buyer's name (A51692)
City of Tampa...
Wolverine Mini Skid Steer Auger Drive & Bit (A50515)
Wolverine Mini...
Komatsu WA3801-7 (A50120)
Komatsu WA3801-7...
3 pt Ditcher Plow (A50515)
3 pt Ditcher Plow...
