John Deere 3020 wants to go in reverse only - as soon as you start it!
   / John Deere 3020 wants to go in reverse only - as soon as you start it! #1
toweraviat
tomball, texas
john Deere 3320 e-hydro
Hello! I have JD3020 with approximately 650 hours. Bought it in 2007 (new). I have to confess that I made one of the most stupid mistakes and connected the battery terminals wrong (negative to positive). As soon as I connected the battery terminals the wire from the alternator to the starter burned. I replaced the wire and checked to make sure that other wires in the harness were not damaged. Now, when I start the tractor it starts going in reverse even when in neutral. The front/rear pedals seems to do nothing. Disconnected the forward/reverse connectors at the bottom but it still goes in reverse! Technically, it should not move with the wires disconnected at the pedals. A friend told me that the onboard logic computer is shot. Can anyone help? Thanks.
   / John Deere 3020 wants to go in reverse only - as soon as you start it! #2
I'd say, if it were me, get it to your Deere dealer.. they can put the computer on it to check out what has failed, or is still mixed up.
Hi! Beenthere. Thank you for the response. That will be my last choice because JD dealership (only 3 miles from house )are saying it will be 6-8 weeks before they can troubleshoot!
   / John Deere 3020 wants to go in reverse only - as soon as you start it! #4
Sorry to hear that, but it is harvest time.
Try for a copy of the service tech manual then. It should help you ferret out the problem.
   / John Deere 3020 wants to go in reverse only - as soon as you start it! #5
Silicon cooks fast on reverse polarity. If its fly by wire, I'd be grabbing my wallet!
I do have the service manual. It says to readjust/recalibrate the pedals. It does not talk about the computer recalibration. I was not able to find any reference in the book regarding the computer.
Please don't scare me.
2015 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2015 Ford F-450...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
Hyster H155XL Forklift (A48837)
Hyster H155XL...
2012 SULLIVAN PALATEK AIR COMPRESSOR (A51222)
2012 SULLIVAN...
