John Deere 3020 Air Filter
   / John Deere 3020 Air Filter #1
Oil Slick
Mountain View, AR
John Deere 3020, 1963 Gas Model
I just bought a 1963 John Deere 3020 gas model and want to change all the fluids and filters before I start using it. I ran into a problem with the air filter element removal. I removed the left side screen and loosened the clamp to remove the dust cup from the bottom of the cleaner body. Operators manual says to remove wing screw and filter element. I can't find a wing screw or anything else that might be holding the filter in. Any suggestions on where this wing screw is or how to remove the element?
   / John Deere 3020 Air Filter #2
A couple different air cleaner setups, but if you go to jdparts.com and put in the model 3020, you will see the two. The wing nut is removed from underneath the air filter.
But looking at the parts you will get the complete picture. Don't know if you have a pre-cleaner or not.
   / John Deere 3020 Air Filter #3
No 1963 3020's. must be '64-'68. Tractor could have oil bath or dry type air cleaner. Dry type was introduced at (ENGINE SERIAL NO. 084000- )
Thanks for the replies. It does have the oil bath type air cleaner and I still can't figure out what holds the element in it. I'm in the hay fields all this week but will get back to work on it next week. Thanks again.
   / John Deere 3020 Air Filter #5
If it is oil bath, I don't think there is an element.
Skid Steer Quick Attach Jack Hammer (A50515)
Skid Steer Quick...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
JLG 1255 Telehandler (A52748)
JLG 1255...
John Deere 648H Grapple Log Skidder (A50322)
John Deere 648H...
2017 Ford Transit 250 Cargo Van (A50323)
2017 Ford Transit...
Unused 2025 CFG Industrial MY50R Mini Excavator (A50322)
Unused 2025 CFG...
