John Deere 300CX 4in1 Loader operation
   / John Deere 300CX 4in1 Loader operation #1
bramleyestate
John Deere 4400 tractor
Hi I have recently purchased a JD 4400 Tractor 900hrs with 300cx 4in1 loader fitted. This uses the electric button on the loader lever to operate the 4in1. When I push the lever to the right a little it opens the bucket, if I continue to push to the right it then annoyingly closers the bucket. I would like to know if this is how JD have set it up, or whether as I suspect another issue? The bucket closes properly if I move the lever to the left. Of note I am sure on a couple of occasions it did work correctly. I have noticed that when I curl the loader bucket pushing the lever to the right again, it appears to temporarily stop at the the same point I am having the 4in1 bucket change direction! Also experiencing heavy power steering at low - middle RPM??
I look forward to your replies, many thanks Jules
2022 Ford Explorer SUV (A51694)
2022 Ford Explorer...
2017 Volkswagen Golf Hatchback (A51694)
2017 Volkswagen...
New Holland 650 (A50123)
New Holland 650...
2 pair -st205/75r15 radial trailer tires (A53421)
2 pair...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
