John Deere 285 lift mechanism
   / John Deere 285 lift mechanism #1
Russ7127
Winchendon, Ma
Kubota L3650
My John Deere 285 has a manual lift mechanism for the mower deck and attachments. I find the mechanism hard to operate in the winter. Has any converted their
manual lift to an electrical mechanism? I am thinking a linear actuator running off 12 Volt DC, but I would appreciate any help on design.
   / John Deere 285 lift mechanism #2
I am looking into the same thing. Have you found an actuator the right size? I have found a lot in the 200-225 lb range but thinking at least 300 or above would be better, otherwise some mechanical multiplication would probably be necessary, making the stroke longer.
2305 w/62C deck.
Steve
   / John Deere 285 lift mechanism #3
If we are talking about a 285 garden tractor
there is a spring to assist the lift that can be adjusted with a crank from the back of the tractor. my guess is more assist is needed for the blower in the winter and less assist for the mower in summer.
hope that helps
   / John Deere 285 lift mechanism #4
Or, the 320 is essentially the same tractor with a hyd lift. I have one that I'm parting out. you would need the transaxle, lines valve and handle.
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A52748)
Michelin CARGOXBIB...
2022 Weber CR5-II HD Reversible Plate Compactor (A50322)
2022 Weber CR5-II...
Truck Flatbed (A50121)
2012 Cat D6T XL Dozer (RIDE AND DRIVE) (A50774)
2012 Cat D6T XL...
1975 Miller 40' Flat Bed Semi Trailer (A50121)
1975 Miller 40'...
