John Deere 2640 Tractor? Help?
   / John Deere 2640 Tractor? Help? #1
Grants351
My father in law is thinking about buying a JD 2640. He found it on Craigslist, so he isnt sure on the hours right now, but the photos seem good. It has new tires and battery. Does anyone know of any problems with tractors. I know that statement is kind of vague, but just looking for some general info. Thanks. GK
   / John Deere 2640 Tractor? Help? #2
The 2640 is a great tractor. It has a very gutsy 276 cu. in. engine. No real problem areas on these models. There are two versions. The early version was before 341,000 serial number and late models were after 341,000, The later ones are somewhat more desirable IMO. They had larger capacity transmission pump and a sturdier Hi-Lo unit. The only real downfall to these were marginal cooling system. If you don't keep radiator perfectly clean, they tend to overheat easily. They could have used a larger radiator. They work OK as long as you are diligent in keeping radiator clean.
2015 Kia Forte Sedan (A50324)
2015 Kia Forte...
2008 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2008 Ford F-150...
Agri Metal Tuff Vac 5000 (A50774)
Agri Metal Tuff...
2021 John Deere 3038E (A50120)
2021 John Deere...
(30) Macro Bins (A50121)
(30) Macro Bins...
2002 INTERNATIONAL 4400 BEVERAGE TRUCK (A52576)
2002 INTERNATIONAL...
