TripleEFarm
I purchase an old John Deere 260 disk mower a few years ago. The first year we used it, it occasionally left strips of grass uncut and the cut was ragged, but you could cut at speeds of 6-8 mph. We changed out the blades and that seemed to help, but it still cut fairly rough no matter what we did; the stripping seemd to be mostly between the second to the outermost disk and the outermost crop divider disk, or the second to the innermost disk and the innermost crop divider disk. Over the past year we noticed it beginning to clog more and more often. Now it regularly clogs even when you are traveling at ground speeds less than 3-4 mph. The clogs happen both on the inboard and and outboard crop divider disks, but most often on the outboard disk. What could be causing this? At first I thought it could be that the mower's belts were too worn or loose, but as it clogs the entire tractor starts to bog down. If the belts were slipping I'd think the tractor rpm wouldn't be affected much by a clog. Could it be that the parts of the crop divider housings (the piece of angle iron and little wings at their bases) that are suppose to help move the crop through these discs are so worn the grass and clover just wraps around these disks rather than getting kicked out the back of the mower? Could it be a combination of the worn crop divider discs and old belts? The crop divider housings are $253 each, so I hate to dump another $500 into the mower if I don't know this is the problem. Any suggestions would be much appreciated.
