John Deere 2520 starting circuit.
   / John Deere 2520 starting circuit. #1
tnm61
JD 2520
I have a John Deere 2520 with an electrical problem in the starting circuit. Getting voltage through the ignition switch but died suddenly and won't start. Lights work but that's it. Hoping someone can point me in the right direction. Does anyone have a description of the starting circuit or can suggest how to trace the problem down? I have confirmed it's not seat switch.
Any help would be greatly appreciated.
tnm61
   / John Deere 2520 starting circuit. #2
To be sure everyone understand's,is engine turning over when you attempt to start? Is there a click each time key is turned to start but nothing else happens?
If engine turn's over but fails to start,fuel shut-off is a weak spot on these machines. See if it's getting 12volts while key is on. If not,jump power to it to see if engine starts.
The engine is not turning around very and there is not clicking when the key comes s turned on. New, fully charged battery.
   / John Deere 2520 starting circuit. #4
We will try to be exact with diagnosis ,if you will try to be exact with symptoms.
"not turning around very":confused3::scratchchin::confused:
Apologies for the mis-typing (auto-correct). The engine is not turning over nor do I hear the fuel pump click in. It shutdown suddenly while mowing as if I turned the key off. Starter won’t turn over and I don’t hear anything when I turn on ignition though the lights work fine and the new battery is fully charged. I confirmed with the volt meter that I am getting voltage through the ignition switch properly (both run and start circuits). I have numbered seat switch to confirm it is not the problem and it made no difference. Since with me in the seat it should not have quit due to pto or transmission interlocks I doubt those are the issue. I traced some of the harness out beyond the ignition switch to see where it is losing voltage but since it’s a big job to pull it all apart I am hoping someone can point me in the right direction or can provide a description or schematic of the start and run circuits.
Not sure why my posts are showing up with weird characters I didn稚 type.
   / John Deere 2520 starting circuit. #7
Leave out as many apostrophes as you can. The forum software doesn’t code them correctly.
   / John Deere 2520 starting circuit. #8
Is the 'click' that you're not hearing the fuel solenoid? If it's not engaging then there will be no fuel transferred to the fuel pump.
Check your fuses, which are listed (hopefully with a handy diagram) in your Owner Manual. There may also be a relay involved and may also be located where your fuses are; if the Manual says that the relays are the same type, you can swap them around to see if the fault transfers to another 'system'.
How many hours does your tractor have?
   / John Deere 2520 starting circuit. #9
I have a Yanmar shop manual which I believe covers the engine in your tractor.
It has a comprehensive trouble shooting section for the starter.
Send me a Private Message with your email address and I will email you a link to download the file.
You might find some good ideas.
John Deere has made available a relay kit for some models which are having difficulty pulling in the starter solenoid.
Over time each safety switch develops some electrical resistance and at a point in time there is not enough power to engage the starter.
After you have gone through the Yanmar stuff and if it seems like another relay would help I can direct you.
Dave M7040
2016 Ford Econoline Van, VIN # 1FDWE3FS5GDC55926 (A44391)
2016 Ford...
2012 Club Car Turf Carryall 252 Utility Cart (A42744)
2012 Club Car Turf...
1999 FORD SUPER DUTY F350 XLT DUALLY PICK UP TRUCK (A43004)
1999 FORD SUPER...
2020 Bobcat E145 Excavator (A42203)
2020 Bobcat E145...
13'x20' Single Garage Metal Shed (A44502)
13'x20' Single...
2017 FORD F-350 DUALLY (A45046)
2017 FORD F-350...
