John Deere 2520 Anti-freeze Leak
   / John Deere 2520 Anti-freeze Leak #1
byak651
Seymour, WI
John Deere 2520
Had an intermintant leak where would see a couple drops under the front of the tractor on occassion, didn't always happen. Couldn't really see where it was coming from, made sure everything was tight and just kept an eye on coolant levels. All winter for snow plowing never noticed it, but last week used it when it was a little warmer and next day was a pretty good leak under it. Closer leak looks like coming towards top of water pump. Any ideas. Started taking it apart, don't have a service manual but have radiator, fan, miscellaneous off. Pump spins by hand with no binding, wondering if it might just be a gasket? Will try to finish getting the pump off today or this week but just seeing if anyone else had this happen and what they did to fix. Also if anything I need to pay attention to when taking the water pump off.
Thanks.
Well only 20 minutes or so since replacing 3 gaskets and no leaks, hope this was the issue. With no service manual took about 2 hours to disassemble, week to get parts shipped on line (approx $35) and another 3 hours or so to put back together. 🤞This was the problem
   / John Deere 2520 Anti-freeze Leak #3
:welcome: to TBN
Missed your 3/26 post.. but thanks for coming back with the fix. :thumbsup: that you won't have any more problem
   / John Deere 2520 Anti-freeze Leak #4
I just had the same issue with my MY2011 4720. took it to the dealer. dealer said JD's repair recommendation is to remove the original sealant (glue?) and replace with paper? (regular) gasket. once done, there's been no more leaks. No warranty...they made me pay.
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
2017 TRAILSTART 40FT DUMP TRAILER (A52576)
2017 TRAILSTART...
1999 FORD F550 BOX TRUCK (A52577)
1999 FORD F550 BOX...
2025 New/Unused Wolverine Snow Pusher (A51573)
2025 New/Unused...
2019 JOHN DEERE 8295R LOT NUMBER 183 (A53084)
2019 JOHN DEERE...
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
