John Deere 2350 Power Steering Cylinder Repair question
   / John Deere 2350 Power Steering Cylinder Repair question #1
sweettractors
Advertiser
Central Kentucky
JD 6403 CHA-JD 3130 CHA
I got the internal steel retaining ring off the shaft with no problem. Replaced the seals and am now reassembling. Is there a trick to getting that steel ring back on the shaft? Ken Sweet
   / John Deere 2350 Power Steering Cylinder Repair question #2
Having a hard time visualizing an internal retaining ring on a shaft? Have a pic?
The steel retaining ring is #3 and it goes on the end of the shaft and is accessed through the port at the base of the cylinder. Ken Sweet
   / John Deere 2350 Power Steering Cylinder Repair question #4
Hi Ken, I haven't worked on these single-acting rams before and I think I'm glad about that... and I may be missing something but:
You have the upper one pictured (RE17356)?
What does the snap-ring do? I can't imagine needing to attempt to work it over the end of the rod by poking something through the 'access port' at the base of the cylinder. That hole is the connection for the hydraulic hose??
Why can't the snap-ring go onto the rod before it inserts into the cylinder?
Curiously, the alternative cylinder assembly (lower pic AL36565) doesn't use a snap-ring :)confused:)
2025 JOHN DEERE X350 LOT NUMBER 152 (A53084)
2025 JOHN DEERE...
2013 John Deere 824K (A53472)
2013 John Deere...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
2013 Ford F-250 Ext. Cab Pickup Truck (A51692)
2013 Ford F-250...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
