John Deere 2320 Fuel Cutoff Stuck
   / John Deere 2320 Fuel Cutoff Stuck #1
arodrigz
Berthoud, CO
JD 2320
Hey all, I’ve got a JD2320 that won’t start. I had a friend stop by who checked a few things and when he pulled the fuel cutoff solenoid found that the fuel cutoff is stuck in the off position. The solenoid works but the valve (or whatever that’s called in the governor) is not springing back. My friend suggested trying to pull it with a magnet which I tried but to no avail. Unfortunately, it’s nearly impossible to fit a strong enough magnet in there to do any good. He also said to drain the fuel and fill the bowl with sea foam then try cranking it that way to see if the sea foam can break up whatever is causing the cutoff valve to stick. I’ve tried that as well but nothing. If I put my finger where the solenoid goes I can push on the valve which compresses maybe 1/16 or so of an inch and can turn it with the pad of my finger but can‘t get it to spring out.
I have a technical manual and in looking at section 30-30-65 through 67, it appears that The governor housing can be removed. I’m not a mechanic but am mechanically inclined. I don’t mind tackling projects but when it comes to diesels and especially anything relating to the engine and timing, I’m way over my head. My friend said I could pull the pump and take it to someone but that I’d have to make sure I set it a TDC. Well, timing is not my thing, lol. Can I just unbolt the governor housing? There’s a gasket on that housing but the JD Parts online does not show parts for the fuel injector pump so I don’t know how I would get another gasket. I’m hoping I don’t have to drop $2k plus on this thing for a new pump and labor. Any ideas would be appreciated.
   / John Deere 2320 Fuel Cutoff Stuck #2
The shut off solenoid powers up w the key switch thru fuses and relays.. if it’s not retracting when u turn the key on or cranking, check the fuse and or relay..
It should start w/o the solenoid in place.. if not, u have a pump problem.. it needs to be removed..
Or.. do u have fuel UP TO the ip inlet.?? That’s what u need to check next..
They don’t run very well w/o fuel.. lol
   / John Deere 2320 Fuel Cutoff Stuck #3
It sounds like the OP has confirmed that the solenoid is cycling but the pump part (rack?) is not moving like it should.
UNUSED CFG NT18K EXCAVATOR (A51247)
UNUSED CFG NT18K...
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
2017 Ford Fiesta SE Sedan (A51694)
2017 Ford Fiesta...
2017 Bayliner VR5 21ft Bowrider Boat with 29ft T/A Boat Trailer (A51694)
2017 Bayliner VR5...
UNUSED FUTURE J5T TON 36" HYD THUMB CLAMP (A51248)
UNUSED FUTURE J5T...
RYOBI 40V BRUSHLESS ELECTRIC 20" PUSH MOWER (A51248)
RYOBI 40V...
