John Deere 2320 and 46 Backhoe
   / John Deere 2320 and 46 Backhoe #1
katt68
2010 JD 2320
Good day ,
hoping you all with your vast knowledge can help me with sourcing some items...
looking for a thumb for my 46 back hoe...
looking for cheap place online to ordwer parts for my tractor like filters etc....
wondering if i can get a larger bucket for my loader?
has anyone had good sucess with PTO connected post hole diggers adn wood chippers?
please advise...
D
   / John Deere 2320 and 46 Backhoe #2
Considering the relatively infrequent changes of fluids, I suggest you stick with the Deere filters. It's not like you're going to need these anymore frequently then 12 months...and you're only looking at (worst case) 30-40 bucks for the oil and fuel filters. Hydraulic filter/fluid changes might be every 2-4 years, depending on your annual usage of the tractor.
As far as the larger bucket...they're available. Just make sure your tractor can handle the greater weight (loaded) safely.
As far as wood chippers....there are a lot of TBNers who have them, including me. That said, if you have less then 20 PTO HP, you'll be limited in the size wood you can chip. I have an older Woods 5000 chipper/shredder. Woods' HP recommendations are 15 PTO HP minimum to 30 PTO HP maximum.
thanks Roy,
where can i find dealers for the larger bucket?
you say about PTO HP, my tractor is a 24 HP ...
does that mean the PTO is 24 HP also? or is it just engine?
   / John Deere 2320 and 46 Backhoe #4
thanks Roy,
I'm guessing your tractor has 24 Engine HP and less then 20 PTO HP. These specs should be in your operator's manual and I suggest you read that ASAP!
As far as larger buckets, there are aftermarket fabricators...do an internet search for "Compact Tractor Front End Loader Buckets" (leave the quotes off).
   / John Deere 2320 and 46 Backhoe #5
If I recall right, the 2320 pto is 18 HP.
   / John Deere 2320 and 46 Backhoe #6
That is correct. the 2320 has 18pto hp.
   / John Deere 2320 and 46 Backhoe #7
Good day ,
looking for cheap place online to ordwer parts for my tractor like filters etc....D
If you are looking for a mechanical thumb check out Bro-Tek. I don't know if he has one for the JD 46 or not. There are others as well. Just do a search.
Regarding buying JD parts at a discount I would suggest Greenfarmparts.com and greenpartstore.com. Greenfarmparts.com will have some good discounts starting tomorrow.
   / John Deere 2320 and 46 Backhoe #8
Yes Bro-Tec has them for the #46 backhoe
   / John Deere 2320 and 46 Backhoe #9
Don't be too quick to buy a bigger bucket. I have a 2320 with the 46 backhoe and have both the 12" and 9" buckets. This spring I had to plant 200 trees and thought the 12" would work best for 2' x 2' x 2' holes. After struggling with the 12" for about 40 holes I decided to switch to the 9" for better/quicker penetration. Found that was the right choice and it was a lot easier on me and the equipment.
2022 WACKER NEUSON G25 20KW GENERATOR (A45046)
2022 WACKER NEUSON...
1996 Monon 45X96 Dry Van Trailer (A44789)
1996 Monon 45X96...
1995 HMDE END DUMP (A45046)
1995 HMDE END DUMP...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A44391)
2007 International...
13'x20' Single Garage Metal Shed (A44502)
13'x20' Single...
Cub Cadet 2wd Tractor (A44501)
Cub Cadet 2wd...
