John Deere 2305 Temp, Oil and battery lights don't work.
   / John Deere 2305 Temp, Oil and battery lights don't work. #1
JayHo
John Deere 2305
Hello all,
I have checked the bulbs as well as the 4 fuses under the hood and they are all good. But when I go to start the tractor they don't come on as they should.
With this tractors tendency to overheat because of the grass clippings covering the outer and inner grills I need to get this fixed asap.
Does anyone have any ideas on what may be going on?
Thank you.
   / John Deere 2305 Temp, Oil and battery lights don't work. #2
:welcome:
Welcome to the forum!
I'm going to move this thread over to our John Deere section. Someone over there should be able to offer advice.
   / John Deere 2305 Temp, Oil and battery lights don't work. #3
look at the main harness going to the cluster, look for a main power wire and check that with a vom.
I have a multimeter. I can say that even though i have installed a new battery, about a month ago, and I still have to jump start it. What are you thinking? Thank you.
   / John Deere 2305 Temp, Oil and battery lights don't work. #5
What's you VOM tell you???
2010 Ford F550 Service Truck (TITLE) (NOT RUNNING) (A50774)
2010 Ford F550...
2009 Kubota RTV1140 (A50121)
2009 Kubota...
(3) Military Transfer Cases (A50121)
(3) Military...
RIDE AND DRIVE INFO (A50774)
RIDE AND DRIVE...
2003 Ottawa Spotter Truck (A50120)
2003 Ottawa...
