John Deere 2240
   / John Deere 2240 #1
willy44
MI
John Deere 2240
Ok so my father recently bought a John Deere 2240 with a 143 loader, and the tractor only has 2100 hours on it. However he is aging in years so any problems the tractor has falls back on me. So all that being said after the tractor has been used for a while say an hour and a half or so doing light work around the house the transmission becomes hard to shift. My experiences so far have been that when the clutch is pushed all the way in and the tractor is idling both the high, low, and reverse ranges as well as the 1-4 gearbox are still spinning like the clutch is still engaged. However if you take the tractor out of gear you can shift the range no problem and vise versa. Now I'm hoping that it could just be that the clutch needs adjusting and that the tractor doesn't need to be broke in half. It shouldn't need a clutch work as it has such low hours unless it was used for a bulldozer but it feels tight when you drive it. Just my thoughts so far, any help would be greatly appreciated.
Thanks.
   / John Deere 2240 #2
Have you checked clutch pedal free travel(IIRC 1.5")? Have you greased throw-out brg(parts key #9 zert)? Have you checked hyd oil level(dipstick by right heel when sitting in seat)?
   / John Deere 2240
I checked the hyd oil and it's good, as well as the clutch pedal free play which I measured around 1.5 or 2 inches, however when I pulled the circular acess panel off to grease the throw-out bearing I couldn't find any zerks anywhere in there. When I drove it today I noticed that the tractor shifts fine when the trans is cold, to add another piece to the puzzle.
2000 FORD F-350 SUPER DUTY (A50854)
2000 FORD F-350...
ALLMAND 45KW MAXI POWER GENERATOR (A50854)
ALLMAND 45KW MAXI...
John Deere 752 4-Star Hay Tedder - Reliable Ground-Driven Tedding Machine (A51039)
John Deere 752...
2018 BIG TEX 35+5 T/A GOOSENECK (A50854)
2018 BIG TEX 35+5...
2014 Ford F-150 XL Ext. Cab Pickup Truck (A50323)
2014 Ford F-150 XL...
Knapheide Service Body with Liftgate (A49461)
Knapheide Service...
