john deere 2240 shifting issues
   / john deere 2240 shifting issues #1
breezyacres1
mcgregor, mn
john deere 2240
I operate a John Deere 2240, for the most part not many issues but when tractor has used for a while shifting from HI, Low, and Reverse become nearly impossible. some one said to grease the shaft on the inside left side but I have found no zerts nor have any clue where this grease would go.....any ideas, advise would be appreciated..
   / john deere 2240 shifting issues #2
My guess is the detent balls(parts key #4) are rusty and need lubrication. Only way to access the shifter shafts is to remove cover with gearshifts.
   / john deere 2240 shifting issues #3
As Tx Jim said; nothing to grease.
But I wonder if it's something else, since you say "when the tractor has been used for a while" the problem starts. So does it shift OK at first? How long until it starts shifting hard? I wonder if the clutch is heating up, and starting to drag, causing hard shifting? Check your clutch adjustment.
It would not hurt to try and lube the shift shafts. The detent balls are in the transmission case casting. You have to pull the cover with the gear shifters. I would start with a cleaner/rust remover, followed with a lube. You may have to pull the rockshaft cover to access both sides of the shift shafts. Key 13 is the Low- Reverse shaft. Key 16 is the Park- High shaft.
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
2003 DITCH WITCH 3700 RIDE ON TRENCHER (A51242)
2003 DITCH WITCH...
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
2022 CATERPILLAR 259D3 SKID STEER (A51242)
2022 CATERPILLAR...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
John Deere A Tractor (A50514)
John Deere A...
