John deere 2210 u joins
   / John deere 2210 u joins #1
ctothea
John deere 2210
Hello all first time poster on this forum. As the title states I own a 2008 2210 with 700 hours on the clock. From the previous threads I've read prior to the purchase of this tractor a few years ago. I was aware of one the plastic cooling fan that's valuable to damage and the u- joint being just about impossible to grease. And I've tried to grease with the ways others suggest with no luck. The original owner also a friend of my wife's moved out of state hence the sale of it. He claimed that it was always serviced at our local dealership. So I stopped by to ask how they greased them. I recieved a laugh and a sentence followed by good luck. And a mechanic did poke his head out and I asked him the Same question. He said they have a special tool and walked away.
So I'm the type that works on all my own stuff . And the reason above is clearly why I do. After I bought this I did replace the plastic fan and the one u joint at the transmission side. Witch was never greased dry as a bone. So my question is the video I will try and post of a guy replacing the same joints on a 2320 are they the Same dimension as my 2210 drive shaft as the 2320 as it would make me actually able to grease them both. Thanks for any information as I'd rather know before disassembling so the tractor is not down waiting for parts. Ok won't let me post links yet. But it was a napa 410 universal u joint number.
   / John deere 2210 u joins #2
Here is a video.. not the best for focus and holding cam steady... for the Deere 2210 u-joint
How To Fix A John Deere 221 Drive Shaft - YouTube
Found this by searching the NAPA 410 part, which appears to be the one with the zerk in the cap.. maybe of some help.
Thanks I think I'll order the two "410" u joints from napa and see for myself. If not the right I'll just bring in the old and see if they have one with the end grease zerk. Can't have it apart for to long as it's my snow season .
2015 MACK GU713 (A50854)
2015 MACK GU713...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A51039)
2-Row Peanut...
2017 HINO BOX TRUCK (A51222)
2017 HINO BOX...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A51222)
2015 KENWORTH T370...
1995 CATERPILLAR 621E (A50854)
1995 CATERPILLAR...
