John Deere 2210 Charging System Problem
   / John Deere 2210 Charging System Problem #1
dattcomm
JOHN DEERE 2210
I have a 2004 JD 2210 Utility Tractor. Having problems with what I thought was the regulator.
1 - New battery = 12.86 VDC with no load
2 - When started, battery test at 12.75 VDC whoile running
3 - Alternator looks OK and tests at 29 to 64 VAC when running.
4 - When alternator cable unplugged from reulator, battery still measures 12.75VDC so I was convinced that teh regulator was bad.
5 - At the regulator plug, tested teh AC voltage coming in from the alternator adn also the 12.86 VDC which I assume is connected directly to the battery.
6 - Bought new regulator for $130.00 and replaced the old one.
7 - SAME RESULTS!!!!!
8 - I'd like to find the output specs for the alternator (Part # AM879144) and the input/output voltage for the Regulator (M807915)
I always thought that voltage out of an alternator was DC voltage and that a rectifier was needed to convert AC to DC, but if AC voltage is indeed supposed to come out of this alternator, then I guess the regulator converts the AC to DC.
Any help greatly appreciated!!! Thanks
   / John Deere 2210 Charging System Problem #2
Hi, yes the voltage regulator converts the AC from alternator to DC for battery.
Check the following.
1. Make sure that regulator case in well grounded to alt. case. Chassis ground path
of reg. is not reliable. So, if not already there, running a 10 gauge wire from alt. housing to
regulator housing is a good idea. All alt. negative current must travel this route.
2. This is a guess, but if you are getting these high AC voltages at reg. input there is a
very good chance that you have an open circuit between the regulator DC output and
the B+ terminal of your battery. Check for an open fuseible link, open hot lead or a
blown heavy amp fuse between these two units. Quick check would be to see if there is B+
current from battery at regulator dc output terminal. Don't check for volatage only since a
hi resistance with no load will give good volt readings. Instead check for good current flow from
battery at this terminal by applying a load to this circuit. Strike hot wire to gnd and look for fat spark.
When alt a/c voltage is this high it's usually because the dc current has an open or a hi resistance path
to your battery or loads.
cheers,
keoke
   / John Deere 2210 Charging System Problem #3
I know this is an older post , but I thought since the Deere 2210 commonly has a charging problem , I felt I should reply to this. I have a 2004 Deere 2210 that quit charging all of a sudden. To make a long story short DON'T jump right into buying a replacement voltage regulator !!! 9/10 the problem is the charging relay. This relay is located right next to the regulator. Both parts are on the left side behind the plastic shroud below the dash. Any questions , please feel free to ask.
   / John Deere 2210 Charging System Problem #4
I'm having similar issues I'm wondering if you knew the part number for the charging relay as it will help me to locate the part and purchase one if it turns out that's what I need. Thanks
   / John Deere 2210 Charging System Problem #5
Had similar issue with my 2210 replaced regulator no change ran heavy ground wire with no change pulled the safety relay and replaced with another one I had was pleased to have a charging system that worked. Thanks to all that contributed got no help from I'd dealer
   / John Deere 2210 Charging System Problem #6
Chromamaster, welcome to TBN. Don't want to hijack this thread but a couple of years ago I bought some rear tires for my Kubota from a tire shop in Leavenworth, I think they also had a store in Bonner Springs.
I've lost the number for the guy but I believe the store was on 73. They had some very good prices on Titan blems and they have been great. Would you know the name of this shop, I want to buy some front tires now.
I have a soft spot in my heart for Leavenworth, I spent 18 months there as a guard at the USDB, hated to see that they tore it down.
   / John Deere 2210 Charging System Problem #7
   / John Deere 2210 Charging System Problem #8
My best guess is you are talking about tire town, they are on 7/73 in Leavenworth. Hope this helps.
John Deere D110 42in Riding Mower (A49461)
John Deere D110...
2022 John Deere S780 Combine (A50657)
2022 John Deere...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2011 MACK GU713 DAYCAB (INOPERABLE) (A50854)
2011 MACK GU713...
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51242)
2024 AGT...
