john deere 214 t
   / john deere 214 t #1
donais
ramona ca
mf 1547
moron alert, oh wait its me. I was baling this evening, boy what a bad year it is going to be. 2 years ago one of my little fields had 80 bales last year 45 this year 20 bales of oat hay. rain stopped and everything is dying so time to cut. oh back to the story, so i tightened the compressor screws on the bail chamber i guess too tight cause one side broke the spring. so if i find a new spring(any hints) what is the starting point fo adjusting them? thanks jon
   / john deere 214 t #2
You can get a new spring at your friendly JD dealer 247SE EXTENSION SPRING, ADD 62.73 USD. The springs set the weight of the bale so the only starting point is to get both springs adjusted evenly then tighten/loosen springs for correct weight of bales depending on moisture content & type of hay.
(3) 8' High Pole Swinging Gates (A50515)
(3) 8' High Pole...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
UNUSED FUTURE SKID STEER PILE HAMMER (A51244)
UNUSED FUTURE SKID...
(2) ALEMITE GREASE HOSE / REEL & NOZZLE W/ GAUGE (A51244)
(2) ALEMITE GREASE...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
2019 FORD F550 XL SERVICE TRUCK (A51243)
2019 FORD F550 XL...
