John Deere 2120 Oil soaked / Wet Injector?
   / John Deere 2120 Oil soaked / Wet Injector? #1
bigblock76
Bronze Member
Little Britain, Ontario
John Deere 2120, John Deere 3140, John Deere 2950, John Deere 7700 Combine, John Deere STX38
Fired up the tractor this morning to blow some snow away before the big melt starts and once I had it running under a good load I saw smoke coming from the engine.
I thought the exhaust manifold cracked but it looks like its coming from above that, looking more closely I see that one of the injectors is oil soaked. I'm not sure if fuel is leaking down onto it, or if there is blow by coming from under it.
Either way, how are are these things to change if I need to pull them out?
   / John Deere 2120 Oil soaked / Wet Injector? #2
could be return line leaking
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2001 KENWORTH T800 TRI AXLE TANKER TRUCK (A51222)
2001 KENWORTH T800...
1994 PETERBILT 379 SLEEPER (A50046)
1994 PETERBILT 379...
Brent 420 Grain Cart (A50514)
Brent 420 Grain...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
2017 Makita HM1307CB 35lb Demolition Hammer (A49461)
2017 Makita...
