john deere 212
   / john deere 212 #1
al moore
smyrna,sc
john deere 212
anyone ever changed pto on 212 to a after market pto
   / john deere 212 #2
Have two 212's and not what I would call a PTO on either one. Pulley on right side of engine clutches in and out to drive mower deck. Would this be called the PTO? Going to take it to a local heavy duty clutch and joint place that is known for fixing this. Seems like this machine is close to 50 years old.
   / john deere 212 #4
What is wrong with it? The PTO on my 214 works great.
   / john deere 212
wire broke right at the winding coil just wondering if anyone has replaced the john deere pto with a extreme or stens or even a ocura pto john deere wants around a 1000 bucks for the am38404 pto and over 400 for the am38810 for the field coil I may have it fixed took it apart ,found enough wire to soilder to and expoxy the coil working at present ,I would like to still replace with a more compact pto I don't need this double pully set up I was told the other pully was for a snow blower. I have 2 of the 212 a 79 model I bought new with hydraulics and manual pto,the one I am working on is a 87 model - I also have a case 446 which I replaced the onan with a briggs 18 hp vanguard I delieve the case is a 78 model
   / john deere 212
that is your pto there is 2 different one is electric pto clutch the other is a manual both drive the belt for your deck
   / john deere 212
broke wire at the field coil think I have it fixed 212 and 214 are the same pto
   / john deere 212
thanks can I download the manual or refrence it
   / john deere 212 #10
You are right about the two PTOs. I have the manual version.
(10) 20' Continuous Fencing Panels (A50515)
(10) 20'...
CFG Industrial MX15RX (A50121)
CFG Industrial...
2013 Honda CR-Z EX Hatchback (A50324)
2013 Honda CR-Z EX...
2018 Ford F-550 Truck Altec AT40G 40FT Insulated Bucket Truck (A50323)
2018 Ford F-550...
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
