Mowing john deere 212 help please
   / john deere 212 help please #1
david neumann
manistique,mi
john deere 212
hello, is this the proper place to ask for help ?my john deere 212 wont shift out of first gear.anybodys help would be appreciated.
   / john deere 212 help please #2
:welcome: to TBN
Can you tell us what took place prior to getting stuck in first gear?
Where is it sitting now? on a hill, by chance?
Used for just mowing, or are there other attachments ??
thank you for your reply. yes i managed to get it into 2nd gear and then the motor locked up and shut off.
Have you tried rocking the tractor back and forth a bit?
yes i tried to rock it.thank you for your reply.i managed to get into 2nd gear then the motor stopped
and that is where it sits.
:welcome: to TBN
thank you for the replies.i couldnt get it go go into reverse.i use it to mow in the summer.its stuck in my front yard on level ground.i was stuck in first gear ,i managed to get it into 2nd gear,the engine stopped i cant shift it it out of 2nd gear.
   / john deere 212 help please #7
Sounds like it is in both first and second gear.. which locks it up.
Need to take a look in the transaxle, to find out what is wrong here. Should have nothing to do with the engine, except being a dead, locked load.
However, maybe other problems involved as well.
Good luck with it.
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
New Holland 900 Chopper (A50774)
New Holland 900...
2011 BMW X5 xDrive35i AWD SUV (A50324)
2011 BMW X5...
2003 Mercedes-Benz CLK-320 Convertible (A50324)
2003 Mercedes-Benz...
2014 BMW X3 AWD SUV (A50324)
2014 BMW X3 AWD...
Horsch Joker RT32 Speed Disk (A50514)
Horsch Joker RT32...
