John Deere 210c Hydraulic Flow Rate inquiry.
   / John Deere 210c Hydraulic Flow Rate inquiry. #1
MountainDeere
BC
John Deere 210c
I've got a JD 210c Backhoe Loader and I'm looking to use some low flow hydraulic attachments on either the loader arms or the backhoe. The main flow is listed as 17.8 GPM minimum at 2000 rpm. Has anyone had experience running implements off the standard hydraulic circuits on a backhoe of similar size and is it worth trying?
I know there likely won't be much available that directly bolts on and I would have to modify attachments likely which isn't an issue.
I'm just trying to add some extra functionality to perform multiple tasks without having to buy another machine or add a separate power pack for high flow attachments.
   / John Deere 210c Hydraulic Flow Rate inquiry. #2
Welcome to TBN
What type implements are you referring to? Most types of implements should be a problem if attached to tractor hyd system correctly.
I'd like to be able to run a mower on the front and an auger off the backhoe possibly. I may also be interested in a snowblower.
UNUSED JCT SKID STEER QUICK ATTACH HAYSPEAR (A51244)
UNUSED JCT SKID...
Wolverine Quick Attach Utility Hitch Adapter (A50514)
Wolverine Quick...
CATERPILLAR PS-130 PNEUMATIC ROLLER (A51242)
CATERPILLAR PS-130...
1986 GMC Top Kick Grain Truck (A50514)
1986 GMC Top Kick...
UNUSED FUTURE PAIR OF MINI RUBBER TRACKS (A51244)
UNUSED FUTURE PAIR...
UNUSED FUTURE 7T HYD THUMB CLAMP (A51244)
UNUSED FUTURE 7T...
