John Deere 210 Pulley Vibration
   / John Deere 210 Pulley Vibration #1
WV84JD210
Jane Lew, WV
John Deere 210
I have a vibration on my 1984 John deere 210. It occurs when the PTO is engaged to the mower deck and it appears to be from the deck belt tension pulleys. Can definitely feel it in the seat. The main bolt that goes into the engine block is good and snug but the pulley bracket has some play at that location. Is there supposed to be some play in the pulley assembly (other than the movement for the tension spring pivot, etc.)? Is there supposed to be that much vibration at the tension pulleys?
http://youtu.be/Y3ZmUc6Pou8
   / John Deere 210 Pulley Vibration #2
Have you checked the bearings in the idler pulleys? If these start to go bad they can cause vibration.
Out of balance blades on the mower deck or bad spindle bearings on the mower deck will also cause vibration which could be transferred up to the idler pulleys from the belts flopping around.
   / John Deere 210 Pulley Vibration #3
my guess is the same as oldnslo. either bearings on spindles are going or you have out of balanced blades.
Thanks guys, I'll be looking into your suggestions.
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A51039)
2007 Freightliner...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
Ford F-450 Utility Truck (A51039)
Ford F-450 Utility...
2015 MACK GU713 WINCH TRUCK (INOPERABLE) (A50854)
2015 MACK GU713...
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A48082)
2018 Toro...
