John Deere 2040 cuts off
   / John Deere 2040 cuts off #1
mikesells4u
My tractor cuts off for no appearant reason. It is not running smoothly and the idle varies by as much as 400 RPM. It is full of fuel and I have cleaned the priming pump and screen beside the filter. Any suggestions?
   / John Deere 2040 cuts off #2
Have you changed the filter? If not then I would start with that. If filter is good, then I would suspect a bad injection pump.
   / John Deere 2040 cuts off #3
Does it have good fuel flow from tank to in pump? Is the return line plugged up?
Thanks, I was hoping to not have to take of the filter but I can see that is something I probably cannot avoid. The tractor has a front end loader that makes it difficult to pump the primer. The last time I changed the filter, years ago, I did not think I was ever going to get it pumped back full of fuel.
Prior to doing that I will start it up and look in the tank to see that the return flow is normal.
Any more suggestions would be greatly appreciated.
ABO TANK (A50854)
ABO TANK (A50854)
2021 John Deere 6130M 4WD Tractor w 620R Loader, Premium Cab, 250 Hours (A51039)
2021 John Deere...
2018 INTERNATIONAL LT625 SLEEPER (A51222)
2018 INTERNATIONAL...
1991 Cleveland Equipment Trailer (A50514)
1991 Cleveland...
vergenes (A50657)
vergenes (A50657)
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
