John Deere 1640
   / John Deere 1640 #1
zonta223
Platinum Member
Adelaide South Australia
Foton FT404, International 444 with forklift, International B250, Kubota L2000DT, Truck converted to all terrain forklift and lots of other junk
Hi
Anybody body own/have owned one of these?
Have a chance to buy one (yes I know they are old......but not as old as the tractors I use now :laughing:)
Looks in reasonable mechanical condition.
It does have a slow oil leak on the lower left hand lift arm of the TPH. It appears to be coming from around the pin the arm is attached to. Are they a screw in pin or a press fit?.......should I be worried about a cracked rear end casting?
So can anybody tell me are they a "good" John Deere or better left alone.
Good or bad features about this model.
Anybody had one with a FEL..This one has a cab and it looks as though fitting a FEL would not be easy.
Any info would help.
Bob
   / John Deere 1640 #2
1640's were built for sales in Countries other than the USA. Some were built strictly for sales in Spain. To repair the hyd leak the trans oil needs to be drained and shaft(parts key #19 or 32) must be removed to access the seals(parts keys 29 & 30). I would suggest checking the PH of coolant to hopefully eliminate the possibility of buying a tractor that will need the engine liners replaced shortly because of cavitation.
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
Brent 776 Grain Cart (A50514)
Brent 776 Grain...
8-Shank Cultivator (A52128)
8-Shank Cultivator...
AUCTION STARTS HERE @ 9AM (A51242)
AUCTION STARTS...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
