john deere 160 mowing deck won't engage.
   / john deere 160 mowing deck won't engage. #1
dvaidm
Harding mn
3020 john deere and 50 john deere
hello I was mowing on my John Deere 160 yesterday I got off go get a drink of water got back on started up and when I flip the switch engages the mowing deck nothing happened flip the switch a couple times still nothing. not sure what is wrong can anyone help.
   / john deere 160 mowing deck won't engage. #2
Electric PTO clutch is fried. Check with resistance meter and check voltage at connector. With engine off, you should be able to hear the clutch snap. Same way mine failed. ebay: new or used.
   / john deere 160 mowing deck won't engage. #3
or the switch failed. they are known for crapping out
   / john deere 160 mowing deck won't engage. #4
It could be the clutch is going bad, or it could be the switch. I've even seen that happen when the battery is too weak to actuate the clutch.
   / john deere 160 mowing deck won't engage. #5
I concur, found mine to be the pto clutch. Very obviously fried upon visual inspection. Just ordered a new aftermarket unit off eBay for my 120
   / john deere 160 mowing deck won't engage. #6
Or fuse...but fuses blow for a reason.
PALLET OF SQUEEZE OFFS (A45333)
PALLET OF SQUEEZE...
2011 FREIGHTLINER CORONADO 122 SD (A45333)
2011 FREIGHTLINER...
Kubota RTV900 4x4 Utility Cart (A44572)
Kubota RTV900 4x4...
GENIE GS1930 (A45046)
2009 Audi A4 Sedan (A42744)
2009 Audi A4 Sedan...
2006 Nissan Frontier Ext. Cab Pickup Truck (A42744)
2006 Nissan...
