Oil & Fuel John Deere 1530 hard starting
   / John Deere 1530 hard starting #1
ruger4144
Story, Arkansas
JD 1530, IH 484
Hello
I am new to tractorbynet I am pleased to have this opportunity to work with other tractor folks.
I just bought a 1975-75 John Deere 1530. I located it in a field that the grass was taller then the tractor. The owner said that the first owner had it in a barn and had not run it for seven years due to a illness and death. The hour meter is broken but it shows almost 1100 hrs. The tractor looks good and when it runs ( with ether or pulling start ) everything works front end loader, pto, three point hitch, clutch and brakes.
I installed two 420 cca batteries with new heavy gauge battery cable, rewired the starter, dump the fuel and filter and replaced with new. Replaced the rubber return fuel lines. I have checked that all three of the injectors are firing. It turns over fine but it will not fire up.
There is fuel seeping from the injectors and I can't seem to make this stop. There is a lot of blow by from the oil breather and blue smoke from the tail pipe and the oil pan gasket is blown.
My question is where do I go from here?
Thanks for any help
   / John Deere 1530 hard starting #2
If you have a lot of blow by I would say that you probably have a compression issue.
Without enough compression the combustion chamber will not get hot enough to ignite the diesel fuel.
By pull starting you are increasing the rpms and this gives you a little more compression.
Using ether it has a lower flash point and the engine starts.
If you can find a shop that would have a compression tester that should tell you for sure.
You are probably looking at a ring job for starters. Maybe more when you get it tore down.
Good Luck!
   / John Deere 1530 hard starting #3
Replace the pan gasket. It may just need to be run hard to free up the rings. I would consult with a dealer on the injectors leaking; may be they can be rebuilt or need to be replaced. I am NOT a fan of ether for starting, it can do more damage than good. I use the block heater when my 2030 will not start (not a good cold weather starter)
1262 (A50490)
1262 (A50490)
2011 TROXELL 130BBL (A52472)
2011 TROXELL...
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
Toolbox (A51573)
Toolbox (A51573)
1985 Ford Ltl9000 Tender Truck (A53472)
1985 Ford Ltl9000...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
