John Deere 1140 rockshaft won't lower.
   / John Deere 1140 rockshaft won't lower. #1
GrapeFarmer
Windsor, Ontario
John Deere 1020, 2120, White ????
I Pulled the rockshaft cover on my John Deere 1140 a little while ago and ever since, the rockshaft arms won't lower. They have lowered when the tractor was parked over the weekend but as soon as I start it up, they raise and won't lower again. I have tried adjusting the rate of fall lever, draft control, and load sensing adjusting screw in the filler cap all to no avail. I used silicone when I replaced the cover, could some be stuck in the oil port or something like that?
   / John Deere 1140 rockshaft won't lower. #2
Sounds as if L/D control cam didn't make it back to correct location on linkage inside RS housing when RS housing was placed back on trans case.
2021 Nissan Altima Sedan (A51694)
2021 Nissan Altima...
1273 (A50490)
1273 (A50490)
2019 Autocar ACX Xpeditor T/A EZ Pack Front Loader Garbage Truck (A51692)
2019 Autocar ACX...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
