John Deere 1120 splitting problems
   / John Deere 1120 splitting problems #1
Badhabit1492
Texas
John Deere 1120
Long time reader first time posting.
Older tractor with about 9000 hours on it. Trying to change out the PTO clutch since it stops by itself and doesn't turn back on unless the tractor is turned off then restarted.
The problem I'm having is I can't get the dang thing to separate. I can get it to about 1/4 to 1/2 inch apart but it just won't budge after that. I have tried various jack heights and have rocked on this thing pretty hard. I don't know it I'm missing something here but it looks like I have taken out all of the necessary bolts and oil lines.
   / John Deere 1120 splitting problems #2
My best guess would be that the clutch disc is stuck on the trans front shaft. ????
What happens hen you push on the clutch peddle?
Okay it got to work with me a bit. Before i got it to open up when I pushed down the clutch pedal it would move the throw out bearing and engage the three clutch fingers. It made no difference as I tied it off and tried to get it to move to no avail.
After some jack repositions and adding a little tension I was able to get it to separate about 10 inches. Now I see an inner shaft that is still inside the clutch pack and inside the outer clutch shaft. Once again I am in a position where it does not want to sperate any further.
I love watching all the YouTube videos of everybody separating their tractors so easily. I wish I was one of them. Any help or advice would be appreciated.
   / John Deere 1120 splitting problems #4
Probably sticking in the pilot bearing in the flywheel. Minute adjustments of angle and some shock force should free it. hit against a block of wood, not on the trans casing directly. Spray some penetrant - You're going to replace the clutch disc anyway.
   / John Deere 1120 splitting problems #5
Loosen PP bolts that hold PP to flywheel
Just an update of where I am today. After reading your responses I took apart the PP and was able to hit it with a a piece of wood and a hammer the inner shaft released. The bearing that sits inside the fly wheel completely destroyed and lost it's structure. The teeth on the clutch are gouged out pretty good.
I am still accepting any kind of advice I can get.
   / John Deere 1120 splitting problems #8
Well firstly - well done for getting it apart! I'm sorry you had such a difficult and stubborn beast for your first experience.
You are going to need to have the flywheel surface skimmed before fitting the new clutch so the flywheel itself will need to come off.
I'm unsure about your reference to "teeth on the clutch' being 'gouged' - Are you referring to the serrations around the centre disc with those springs? That's the friction plate and is broken apart.
Make sure you replace the thrust bearing as well as the pilot bearing you found as destroyed.
Thanks for the reply Spanner. The damaged teeth are actually on the clutch dism itself. I have uploaded a photo to the aftermath. The splines on the shaft itself seem to show no damage.
I have been spending some time looking at the parts diagrams. To the best of my knowledge I have a single stage clutch. I figure since I only found the one clutch closest to the flywheel.
I figure I need the #1 clutch and the #15 bearing parts. I drew a line through parts that don't seem to be in my machine. Of course thrust bearing as well and flywheel worked out. I do believe the inner part of the #15 bearing ended up staying on the shaft so I'll have to get that off before I bring it back together.
My main question is how does this drive the transmission and the pto? Or am I just totally wrong and course if missing something let me know.
Thanks again
   / John Deere 1120 splitting problems #10
Let's start by my saying I have no idea about your JD;
In your second picture above it looks to me like two shafts,
the outer shaft being hollow and would be the transmission input drive,
the inner shaft being the pto and hydraulic pump drive shaft?
Most tractors that I have split have had independent PTO's there was a splined hub on the flywheel
which drove the inner shaft constantly, with the pto clutch being towards the rear of the tractor.
Before splitting on some of those we would pull the PTO main drive shaft befor splitting the tractor.
Is the PTO on your JD live or independent?
Good luck
2015 KENWORTH T800 CRANE TRUCK (A45333)
2015 KENWORTH T800...
2013 Ford E-350 XL Super Duty (A44501)
2013 Ford E-350 XL...
2015 MACK GU GRANITE (INOPERABLE) (A45046)
2015 MACK GU...
66in Light Material Bucket Skid Steer Connection (A44789)
66in Light...
ALL-STEEL CARPORT W/OPEN SIDEWALLS (A45046)
ALL-STEEL CARPORT...
2006 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A42744)
2006 Dodge Ram...
