John Deere 111- Fuel tank leak
   / John Deere 111- Fuel tank leak #1
Carbon county Utah
John Deere 111
I have an old JD111, and it seems the fuel tank is leaking. It's a plastic tank. What is the best way to fix it, short of buying a replacement?
   / John Deere 111- Fuel tank leak #2
An old plastic fuel tank is very hard to fix. I would look for a replacement.
Ken
   / John Deere 111- Fuel tank leak #3
My tractor's fuel tank had 4 nuts embedded in the bottom that held on a skid plate and you can likely guess what happened after running over a bit of brush, yep all four bolts pulled on the nuts with enough force to crack the tank in each instance. The tank was warranted but it was taking forever (6 weeks finally to get a new tank) so I removed the tank to try a repair. I cleaned up the areas with plenty of acetone to remove all the old diesel, then took a power brush to it with my 4" grinder roughing up the area and widening the cracks a bit. I then mixed up a batch of JBWELD epoxy and layered it on filling in the holes with the nuts. After modifying the tank brackets so they protected the tank from future damage, I reinstalled it. This was in 2010 and it is still on the tractor and not leaking. The new tank arrived about a week later and I still have it in my shop waiting for the leak to appear again. I am not going to take it off till the repair leaks and so far after over 3 years it is still good.
2008 Ford Escape XLT SUV (A51694)
2008 Ford Escape...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
PAIR OF FILING CABINETS (A53843)
PAIR OF FILING...
Toro ProCore 864 Series 64in Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
