John deere 110TLB rear remote kit
   / John deere 110TLB rear remote kit #1
18445mountainman
Newfoundland , PA
JD 110 TLB
Hi, I recently bought a 110 TLB, 99% of the time I am going to use it as a tractor and need rear remotes. I was told by the dealer the rear remote kit is a $2500 option and if it did not come with it you cannot add it later. I'm pretty handy and made a kit T-ing off the front loader arm auxilliary outputs. I've bundled this as a kit and am selling on ebay for people in the same boat I was in. See ebay item 370605709024 , Mine is the first and prototype, the next generation will have no adapters between the hose and T fitting, I am going to find the correct ends to go from the hose right to the T. Cleaner look.
   / John deere 110TLB rear remote kit #3
I plan to "tee" into my loader 3rd function and add couplers at the rear of my tractor. I plan to "tee" in right at the mid valve. Less hose from there.
Did you look at the other end of the hoses where you made the connection to see if tht would be easier or use less hose? Claener yet and lower your costs.
What were the hose to hard line connections? I am guessing ORSF. Your hose looks like NPT threads, then a NPT coupler, then NPT to ORFS female swivel?
What did you have to do to connect the rear couplers? I agree if sales take off the fewer parts the better. Fewer chances for leaks, misassemblely, shipping delays because of parts shortages, etc. K.I.S.S. good luck with your endever.
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
