JOHN DEERE 110 TRACTOR LOADER BACKHOE
   / JOHN DEERE 110 TRACTOR LOADER BACKHOE #1
PHX ALLEYCAT
JOHN DEERE TLB 110 LOADER BACKHOE
DURRING A SERVICE MY MECHANIC PUT A FUSE IN THE #12 POSITION IN THE FUSE BOX. THIS HAS DISABLED THE TRANSMISSION" FORCE CALIBRATION POSITION"
DOES ANYBODY KNOW HOW TO RESET THIS FUNCTION? I HAVE A JOB TO DO AND ITS GOT ME DOWN..... STOPPED
THANKS,
ALLEYCAT
   / JOHN DEERE 110 TRACTOR LOADER BACKHOE #2
Sorry about your problem. I've never had that issue with mine so I can't help you. By responding to your post hopefully tis will 'bump' it back up to the top of the list so someone who can help you may see it. Good luck!
   / JOHN DEERE 110 TRACTOR LOADER BACKHOE #3
Alleycat,
I'm guessing you have figured this out by now. Why did your mechanic do that, was a part replaced?? Here is an excerpt from the TM. Basically, when you move that fuse, you have to complete the calibration, it will render the machine inoperative, until it's complete.
Note: Entering the calibration mode resets all
controller values to zero. Because of this, the
calibration process must be completed before machine
can be driven. If a complete system calibration was
attempted and failed or was interrupted, machine
movement may be lost.
Let us know if your still down.
   / JOHN DEERE 110 TRACTOR LOADER BACKHOE #4
Hey there Alleycat,I have the same problem,Wondering if you had resolved the problem.Had someone put a fuse in #12 position fuse slot.Now my tractors transmission will not go into gear.Could i get some info from you on how you got yours back up and running. Thanks Ronnierodz Or can anyone help me out.
   / JOHN DEERE 110 TRACTOR LOADER BACKHOE #5
I've made the same mistake.
In reviewing all the previous threads, it appears so has figured a way to fix this short of having JD come out and re-calibrate - is that correct?
2014 Dynapac CC4200 (A51039)
2014 Dynapac...
2025 8ft Office Shipping Container (A49346)
2025 8ft Office...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
2022 Case IH Steiger 420HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
AIR POWERED TONGS (A50854)
AIR POWERED TONGS...
Adams Conveyor (A51039)
Adams Conveyor...
