John Deere 110 TLB wont move fwd or reverse
   / John Deere 110 TLB wont move fwd or reverse #1
Kcorey
North Madison, CT
Machine was working perfectly, then stopped and wont move forward or reverse. Getting two short and two long flashes. Proportional solenoid valve? Anyone have the tech/service manual i could buy from them in email? Thanks
   / John Deere 110 TLB wont move fwd or reverse #2
Mine was the flywheel sensor. Could only use the creep function to move it
I replaced that 3 years ago because it was intermittent moving but would drive with the creeper switch. Now it is completly dead no movement at all
   / John Deere 110 TLB wont move fwd or reverse #4
That was my best guess... the Dealer was of no help other than bring it in and they bill so much per hour diagnostic time.
Sorry.
   / John Deere 110 TLB wont move fwd or reverse #5
I had same issue dealer came to me as a field service call thought it was a potentiometer issue they tried to field adjust using john deere pro-gramer and lap top but had no signal dialed it in with a meter. But that wasn't the issue the picked it up took it to shop this was my green dealer they had to call the yellow dealer to figure it out. $1200.00 later and it runs great I can not remember exactly what it was I could look at my bill tomorrow I believe it was a transmission module they had to split it to fix it.
Yes if u could look at your bill I壇 greatly appreciate it!
Were you able to take a peak and see what it was that they replaced?
   / John Deere 110 TLB wont move fwd or reverse #8
What is the serial number of the tractor? I may be able to help
LVO110T210340 is the serial number
So far i have ohms tested both fwd and reverse proportional solenoid they test ok, continuity tested the wiring both feed and ground from the HST controller to fwd and rev solenoids and found no open shorts.. replaced the flywheel speed sensor, calibrated both the fwd and rev potentiometers and throttle pot. I am going to try and test ground speed sensor next.
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
2019 Ford F-550 Bucket Truck (A51039)
2019 Ford F-550...
2025 KG45 UNUSED U-Type Screw Pin Shackle Set (A50860)
2025 KG45 UNUSED...
2014 Dodge Ram 1500 Pickup Truck (A50860)
2014 Dodge Ram...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2018 Mitsubishi Mirage ES 4D Hatchback (A50860)
2018 Mitsubishi...
