John Deere 110 TLB after 20 running time transmission starts jerking motion,
   / John Deere 110 TLB after 20 running time transmission starts jerking motion, #1
Tractorskinner
Camarillo Ca
John Deere 110 TLB
Replaced flywheel sensor and rear transmission sensor.....15-20 min ran fine, then started same jerking mode.
Tractor can be driven with flywheel sensor unplugged, however have listen to engine rpms so not to lug it.
Going to try another flywheel sensor to see if I received a defective part, also. Counting the hyd, light flash for code read.
Anyone have any other solutions ?
   / John Deere 110 TLB after 20 running time transmission starts jerking motion, #2
:welcome:Post your problem in the john deere forum.
   / John Deere 110 TLB after 20 running time transmission starts jerking motion, #3
No... thankfully the sensor was the fix on mine.
I've only put about 20 hours on it since... so no long term report.
The one I took out looked OEM and like it had been there for a long time.
   / John Deere 110 TLB after 20 running time transmission starts jerking motion, #4
Welcome to TractorByNet!
I moved your thread to the Construction Equipment forum. :)
   / John Deere 110 TLB after 20 running time transmission starts jerking motion, #5
Tractorskinner, I had the exact same problem after I changed the flywheel sensor in my 110. Did you ever figure out what the actual problem was??
22008 (A51694)
22008 (A51694)
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
2012 KOMATSU GD655-5 (A52472)
2012 KOMATSU...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A52748)
2022 Gravely...
Agrotk 72" Skid Steer Broom, New  (A52384)
Agrotk 72" Skid...
