John Deere 1050 Transmission/Hydraulic Heater
   / John Deere 1050 Transmission/Hydraulic Heater #1
Big Weld
JD 1050
Hello,
Has anyone installed the heating element in the transmission/hydraulic heater in a John Deere 1050?
I was wondering if the cap with the hole is the same as the cap without, except for the hole?
My idea is drill and tap the existing cap to install the element or use a weld on fitting for the cap.
Thanks,
Peter
MQ POWER 135 KW GENERATOR (A48992)
MQ POWER 135 KW...
PTO-60 Pull-Behind Turf Renovator (A49346)
PTO-60 Pull-Behind...
PUMP JACK (A48992)
PUMP JACK (A48992)
2012 IC Corporation PB105 School Bus (A48081)
2012 IC...
2015 INTERNATIONAL 4300 BOX TRUCK (A50046)
2015 INTERNATIONAL...
2015 John Deere 5065E 65 HP 4WD Utility Tractor (A49346)
2015 John Deere...
