John Deere 1050 engine options
   / John Deere 1050 engine options #1
hwmcclure
John Deere 1050
I'm the proud new owner of a JD 1050, 4x4, 1986, with a nice big round hole in the left side of the crankcase. Threw a rod. Probably a two or three inch diameter hole, below the front cylinder. I've been advised to just get a working, used, 3T90T-J to swap in, but I was wondering whether there are any alternative, preferable engines that I should consider. I'm new to JD. Or whether I should try a rebuild. But I suppose if you need a crankcase, a rebuild doesn't make much sense.
   / John Deere 1050 engine options #2
The entire tractor is made by Yanmar. And it's a YM4300 just painted JD green.
Known engines to bolt on an run are the 3T90, 3T90T, and 3T80.
Not see your location in the avatar field to the left. But, if you live down south, one can pick up these engines easily with or without the turbo.
The turbo adds 4 to 6 Hp depending on engine speed. Great for rear 3PT tillers in action. Not so good for post hole augers as busting the tip or cutters off are common events.
If you need free manuals in PDF, we got them at the tiny link in my signature down below,
Yanmar Tractor Owners Group. US models, Gray market models, Cub Cadet models, RK models, even our green siblings known as Deere's.
A valuable source for owners of Yanmar tractors.
Now about the issue of blowing a rod out the side. This is typical when someone thinks they can rebuilt the fuel pump with no prior experience. There is a governor rack on the back side. If it got bound up and jumped to over the tach limit of high revs, it's typical to blow the engine. Hum, seems I know about this first hand, ah yes, my old JD850.
2017 JOHN DEERE 210G LC EXCAVATOR (A45046)
2017 JOHN DEERE...
2017 Bomag BW90 AD-5 Vibratory Articulating Tandem Smooth Drum Roller (A42742)
2017 Bomag BW90...
2006 JLG 600AJ 4X4 ARTICULATING BOOM LIFT (A45046)
2006 JLG 600AJ 4X4...
Skid Steer 42in. Pallet Forks (A39855)
Skid Steer 42in...
2013 Kenworth T400 Palfinger 20M Forestry Grapple Truck (A44571)
2013 Kenworth T400...
Goose Neck Bed Mounted Ball Hitch (A40784)
Goose Neck Bed...
