John Deere 1032 Wheel Bushing Replacement
   / John Deere 1032 Wheel Bushing Replacement #1
JohninCT
Platinum Member
Central CT
Struck Magnatrac 6000, Kioti DK40SE
I've got a JD 1032 walk behind snowblower that I'm trying to recondition before winter. Need to replace the auger and impeller bushings. Got all of those out real easy. I've got one bad wheel axle bushing that needs to be replaced. Problem is that I can't see how the axle comes apart to get it out through the bushings.
Anyone out there have one of these machines that has taken the axle apart before?
I took a roll pin and small bolt out that went thru the shaft. Took the chain wheel off and took the differential housing apart (full of dust/rust :eek:). Bevel gears on each shaft half won't come off. Maybe they are rusted on I don't know. But, what I've taken apart so far and how it came apart has me convinced that this is NOT the way it was originally put together or intended to come apart. Been looking at JD parts diagram and get no real help there.
Maybe a fresh look on another day will let me see what I'm missing. Any ideas?
Manac Walking Floor Trailer (A50322)
Manac Walking...
New/Unused 10ft Workbench with 15 Drawers (A51573)
New/Unused 10ft...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A53472)
Kubota 24in Quick...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
