John Deere 1020 tractor wanting to stall auxiliary hydraulic
   / John Deere 1020 tractor wanting to stall auxiliary hydraulic #1
60lp
Bronze Member
Friendsville Tennessee
1020 john Deere,300B Deere backhoe,773G turbo Bobcat,LT30 Woodmizer sawmill with 2-cylinder air cooled diesel Engine
Wanting to know how to install hydraulic remotes on rear of my tractor but don't have the cash to use install Deere parts just want to go with a simple spool valve and like to see the process step by step my s/n162035T
   / John Deere 1020 tractor wanting to stall auxiliary hydraulic #2
You can install a spool valve with rear breakaway couplers by tying into hyd system similar to installing a FEL control valve.
   / John Deere 1020 tractor wanting to stall auxiliary hydraulic #3
What are you trying to operate with the hydraulics ? Which front pump is the 1020 equipped with.
   / John Deere 1020 tractor wanting to stall auxiliary hydraulic #4
May I ask "how which pump" will affect attaching a spool valve to a JD 1020? Spool valve should be attached the same no matter what size hyd pump tractor has.
It's the very large pump just like the one on my 300B backhoe
   / John Deere 1020 tractor wanting to stall auxiliary hydraulic #6
The 1020 was only ever built with the small 1000 series pump. Either 6.75gpm four piston 11cm 1000 series pump or the 13gpm eight piston 23cm 1000 series pump.
The 300B was built with a 40cm 2000 series pump rated at 23gpm.
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
TOYOTA 7FGCU25 LP SIT DOWN FORKLIFT (A52472)
TOYOTA 7FGCU25 LP...
2011 JACK  130BBL (A52472)
2011 JACK 130BBL...
2006 Ford Fusion SE Sedan (A51694)
2006 Ford Fusion...
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
