John Deere 1020 loosing antifreeze
   / John Deere 1020 loosing antifreeze #1
Arob
John Deere 1020
I have a John Deere 1020 utility. I bought this tractor last year and recently noticed after running it to move snow that the antifreeze comes out the overflow. The tractor has never overheated according to the temp gauge, I have also felt the block and the head after using and it as well did not feel hot, I have replaced the radiator cap, the radiator neck appears to be fine. It appears the previous owner had installed a new water pump. The tractor starts right up and runs great, no sign of antifreeze in the oil. Any ideas?
   / John Deere 1020 loosing antifreeze #2
How much coolant are you losing? The 1020 has no coolant overflow tank like newer models, so you can't keep the radiator level full. You need to keep it about an inch below the filler neck to keep it from pushing out. If it continues to push out coolant after that, you could have a compression leak into the cooling system. Head gasket leak, cracked head or cracked cylinder liner are possibilities.
I loose about 5oz each time i use it, the other day I added antifreeze and added about a gallon and filled it just till I could see it so it.
Case Maxxum 140 (A50120)
Case Maxxum 140...
1998 Dorsey Trailer, VIN # 1DTP16K29WG052604 (A51572)
1998 Dorsey...
2007 WABASH 53FT DRY VAN TRAILER (A52576)
2007 WABASH 53FT...
2022 JOHN DEERE 331G LOT NUMBER 99 (A53084)
2022 JOHN DEERE...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2005 Caterpillar 430D 4x4 Extendahoe Backhoe Loader (A51691)
2005 Caterpillar...
