Oil & Fuel John Deere 1010 Gas "no start problem"
   / John Deere 1010 Gas "no start problem" #1
Rhode Island USA
NH TC40DA w/all options except ss
Hello John Deere guys !! We are helping a friend try to get his 1010 running and we are stumped. Is there any quirk about these tractors that we might have missed? It is a gas tractor, 12 volt positive ground system. We have spark at the points, plugs, and coil,,,,,,not great spark, but seems like enough to fire it. I'm just thinking maybe there is something we're missing. Any help or ideas would be a big help. Right now, we are going to try a new set of points and condenser. We seem to have good compression. It was a running tractor and now it won't do anything, not even a hint of firing. We tried a different coil,,,,different plugs,,,,,running out of ideas.
   / John Deere 1010 Gas "no start problem" #2
I'm sure you've checked, but how about fuel? While cranking have you sprayed a little starting fluid in the intake to see if it tries to take? Look at the plugs after trying to see if their wet from fuel. Pull the #1 plug and make sure it's still firing on t.d.c.. The 1010 is a good old tractor and kind of hard to find around here. Sounds like something simple or the timing has jumped.
   / John Deere 1010 Gas "no start problem" #3
I am have a new problem with my 1010 tomorrow I am going to check point gape and timing if i can find it on line.
I had to clean carb out also dumped and refilled the oil bath air fliter. You will be supprised by what you find in there.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A50397)
80in HD Tooth...
2006 Hino 268 Truck, VIN # 5PVNJ81T962S11110 (A48836)
2006 Hino 268...
2016 POLARIS RANGER ETX EFI 00HC RTV (A50459)
2016 POLARIS...
KUBOTA L2501D TRACTOR (A50459)
KUBOTA L2501D...
Lot of 4 Unused ST205/75R15 Tires (A49346)
Lot of 4 Unused...
2010 Volkswagen Jetta Sedan (A48082)
2010 Volkswagen...
