John deer LT 155 belt
   / John deer LT 155 belt #1
rubadub
John Deere garden tractor 111 john deer garden tractor model lt155 john deere garden tractor x728
I changed out the original mower deck belt that came with my LT 155 that I bought new in 2001, it was getting pretty sloppy. It was a piece of cake, didn't even have to take the mower deck off, fired her up and she cuts like a new one.
Thats the only thing I have had to do other then oil changes, oil filter, air filter and blades, no repairs for 11 years, anyway just passing this on.:)
Rob
   / John deer LT 155 belt #2
I was given an identical machine crushed by a tree, which anfter removing the crushed parts, turned the key and she fired right up!!I bought one with a blown engine on ebay so im going to swap engines and part out tue rest. great little machines thought!!
   / John deer LT 155 belt #3
I liked the Kohler 15HP engine, but i went through belts like crazy, plus a couple of deck timing belts. could never get the belts to not rub in a couple of spots. maybe our less than perfect areas, but they weren't that ugly i didn't think.
I guess I could mention I bought the John deere belt.
Rob
   / John deer LT 155 belt #5
I mostly used Dayco belts. it was the rub that killed mine. we had some tight side-hill and off-camber areas, which caused the deck to pitch just enough to rub the belt. There were a couple of deck adjustment bolts and the deck pulley brake stuff that always seemed to be in belt path. I remember I zip cut one bolt flush with the nut to try and fix one of my belt rub areas. Previous owner gave me his service records and I saw he went through several JD belts aswell.
Looks like in your case it didn't matter what belt.
Rob
2019 Allmand Bros Maxi-Lite II 15kW Towable Light Tower (A52377)
2019 Allmand Bros...
2021 Allmand Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand...
2011 FONTAINE 48 FOOT STEPDECK (A53843)
2011 FONTAINE 48...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2007 Amkus Rescue System (A53421)
2007 Amkus Rescue...
2016 Ford E-450 LP Handicapped Bus (A53422)
2016 Ford E-450 LP...
