shaughnessy
- Joined
- Jun 28, 2010
- Messages
- 14
- Tractor
- John Deere 1140
I have a Mannheim JD 1140 that is about 30 years old. Today I hitched up my drum mower to make hay and the lift arms won't lift it off the ground. I've been using the mower for the last few years, and the tractor has never struggled to lift it before. The tractor is very rarely used. I only use the lift arms during two periods each year- in the summer when I make a small amount of hay (c 300 conventional small bales), and in the spring when I use the pick-up hitch with a trailer to muck-out my sheep shed. The lift arms will go up and down if I disconnect the mower. The tractor has a loader, which is working normally. The power steering is also working ok. There is plenty of hydraulic fluid, and the filters where changed last year. From the behaviour of the loader and the power steering I conclude that the hydraulic pumps are OK. Given that the lift arms operate unloaded, but not under the load of the mower, I'm assuming that either a seal is failing under pressure, or that there might be some sort of relief valve that is operating when it shouldn't. I will get the service guys out tomorrow (Monday), but will lose a day's good weather, so if any of you have any suggestions in the meantime about what I might investigate then I'd be very grateful. I don't have any pressure guages, so I can't perform any tests that require them.
Kind regards
Kind regards
