JM284 loader removal
   / JM284 loader removal #1
Foggy
Atherton Tablelands, Australia
Jinma 284LE (2006)
Apologies if this has been asked and answered, but....
I've recently bought a Jinma 284 with a 4in1 loader, and I want to remove the loader to make mowing easier (lots of trees on my property). Can someone post the procedure for removing the loader?
It looks like it should be pretty straightforward - remove the QD pins, lift the loader out of the vertical column support brackets, loop the hydraulics. Now if someone could fill in the details :)
I found this link (Loader Removal Procedures) for removing a kubota loader, and conceptually the Jinma ought to be the same, but, I'd rather not try it and have my loader topple onto my nice new tractor
Advice appreciated...
Cheers, Foggy
   / JM284 loader removal #2
Can you post several photos of your loader? Many have braces that are stored inside the cross tubes. You take them out to hold up the loader when removing. Does yours have that?
Rob,
Will try to post photos later, but yes, I have braces (if you mean support stands).
Cheers, Foggy
   / JM284 loader removal #4
Sorry Fog, I've never removed mine and probably won't, I use it for everything!!
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
2010 International 4300 2,000 Gallon Water Truck (A52377)
2010 International...
1 Bridgestone 255/70R 22.5 and 1 Toyo M-872 12R 22.5 Tires (A51573)
1 Bridgestone...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
2025 INDUSTRIAS AMERICA 227T 7' X 22' HYD TILT TRL (A51247)
2025 INDUSTRIAS...
