JM224 chassis
   / JM224 chassis #1
bruce1966us
Platinum Member
Tennessee
Does anyone know if the JM200 series and 220 series use the same chassis/frame?
Thanks,
Bruce
   / JM224 chassis #2
the 22, 25, and 28 horse are all the same chassis
   / JM224 chassis #3
The only thing that could vary the chassis length is 2 vs 3 cylinder if you were quiestioning for loader mounting
   / JM224 chassis #4
The 224 chassis is smaller than the 254/284.
The 224 is the same as the 184/204/224.
   / JM224 chassis
I was wondering what the difference was from a weight standpoint.
Thanks,
Bruce
   / JM224 chassis #6
the 3 cylinder 224 and the 3 cylinder 284 are the same, exact chassis. same tires, same loader mounting brackets, same size, period. i have 3 of the 224's now, in stock, and 2 of the 284's left. (LE versions), and they are the same. only difference or variation possible is if tractors are ordered with turf tires instead of ag tires, there is a difference in the fiberglass fenders, particularly the size. if you order tractor with turfs, then ag tires will not fit on them, but if ordered with ags, you have plenty of clearance to install turfs.
i do not know specifically the exact weight, but i can't see how there would be absolutely any difference in the weight.
when i get time, i may just run 2 of them down to the local elevator just to find out for sure, but then again--when will i find time??
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
66 Tomahawk Skid Steer Bucket (A52384)
66 Tomahawk Skid...
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
JOHN DEERE 635F 35' HYDROFLEX PLATFORM HEADER (A51247)
JOHN DEERE 635F...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
