JM 284 LE IGNITION SWITCH REPLACEMENT
   / JM 284 LE IGNITION SWITCH REPLACEMENT #1
corey
Wellsburg, WV
JINMA 284 LE & YANMAR 240 D
With over 100 hours on my 2004 JM 284 LE I want to replace the JM ignition switch with a Ford ignition switch.
Appreciate clarification on the appropriate Ford part number for this ignition switch.
I've found multiple part numbers for the ignition switch doing a search and want to avoid getting the wrong one.
Thanks in advance for your help.
corey
   / JM 284 LE IGNITION SWITCH REPLACEMENT #2
Ford has numbered and renumbered that switch several times, but each should cross over to whatever the current number might be. Just print out my Ford Switch Mod instructions and give it to your parts man. Between the picture and the part number he should be able to get you the right one
//greg//
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
1988 Kenworth W900B Dump Truck with 3406B CAT (A53473)
1988 Kenworth...
LIKE NEW John Deere 10 Lug Sprayer Wheels and Tires (A53473)
LIKE NEW John...
2004 Kubota RTV 900 (A50123)
2004 Kubota RTV...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
