jinma Oil capacity y380
   / jinma Oil capacity y380 #1
jaroban
TX
Kioti dk40se
Can you tell me how much oil the y 380 holds including the filter. I really think that Jinma needs to spend a little $ on there manuals. There is not enough information. Thanks Robby
   / jinma Oil capacity y380 #2
Re: jinma Oil capacity y380
My manual says 3.86 qts, but that's not saying with or without a filter change. I agree, it's lacking in info. Mine took an even 4 qts, and looked good on the stick and about matched what I drained out, but that's a hard way to tell. Oh, that's replacing the filter.
   / jinma Oil capacity y380 #3
According to Nortrac web site....3.68 qts. But probably an even 4 with the filter would do great.
Thank you . I guss the northern manual is better than the jinma manual that I have. Thanks again Robby
   / jinma Oil capacity y380 #5
</font><font color="blue" class="small">( My manual says 3.86 qts, )</font>
That's interesting Rick. I was under the (apparently false) impression that there was little difference between the Y380 and Y385 other than cyliner bore. Since the Y385 engine oil capacity is 6 liters, the Y380 crankcase must be different as well.
//greg//
   / jinma Oil capacity y380 #6
Actually, the manual says 3.68 qts. I got my numbers reversed. I was looking at the Nortrac site and your right about the differences between the 380 and the 385. The 385 is listed as holding 6.36 qts. There must be a sump on that engine pan. Mine is pretty flat on the bottom. There's a Northern Tool about 40 miles from me and last time I was there they had a 25hp 385 on the lot. I'll have a look now that you got my curiosity up next time I'm out that way.
   / jinma Oil capacity y380 #7
That makes sense for the Y385; six liters is the equivalent of 6.34 quarts. Just didn't realize the Y380 held that much less oil
//greg//
2020 Chevrolet Express (A50123)
2020 Chevrolet...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
(1) FRIGIDAIRE REFRIGERATOR (A51248)
(1) FRIGIDAIRE...
ECHO CS-3510 CHAIN SAW (A51248)
ECHO CS-3510 CHAIN...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
JOHN DEERE 16B GRAIN DRILL (A51247)
JOHN DEERE 16B...
