Michael_C
Bronze Member
I am trying to adjust the anvil on the Jinma chipper, but I don't think my approach is good. I'm using a piece of sheetmetal with a single bend, going down it's length, as a shim. The blades are not vertical with the bottom of the blade being roughly .100" closer to the anvil than the top. I place the shim between the anvil and blade and have the flywheel rotated such that the left side of the blade is at the top of the anvil. The top of the anvil is just below the middle of the blade when you look at the right side.
When sliding the anvil towards the shim, the left side is backed by the bottom of the blade, and the right side is backed by ~ the middle of the blade. This could result in ~.050" difference between in gap from left side to right. If I use a .020" shim, the blade will contact the anvil on the right side. If I use a .050" shim, I get a light rubbing on the right side when rotating the flywheel.
What's the best way to adjust the anvil/blade gap? Adjust when the center of the blade is aligned to the top of the anvil? Or, set the gap on left side, first and then the right side? Some other approach??
