Jinma hydraulics and power steering stopped working
   / Jinma hydraulics and power steering stopped working #1
ryanrancher
Jinma 25hp
Hi There,
I have a Jinma tractor and when i was mowing the field suddenly the tractor wouldn't turn. Then i realized the front end loader was not working as well as the 3 point hitch. I looked to see if i was low on hydraulic oil... and i was, so i put a bunch in. However, none of the hydraulics or power steering is working still. Any ideas of what it could be or what i can do?
Thanks!
   / Jinma hydraulics and power steering stopped working #2
I would check the engine oil. If it's overfull, you have a bad seal in the hydraulic pump, blowing your hydraulic oil in to the engine.
Some have had problems with quick disconnects at the loader coming loose, dead heading the pump, and causing a failure. You can probably get better info posting on the Chinese forum.
Stan
Stan
What is a good chinese tractor forum to go to.... any recommendations?
   / Jinma hydraulics and power steering stopped working #4
I referring to the chinese forum on this site. Scroll down to the brand specific forums, and you should find it.
Stan
   / Jinma hydraulics and power steering stopped working #5
This site is the best for Chinese tractors. I have not had this problem but some have. You blew the pump seal or the pump itself by dead heading it. Probably the cheap Quick Connects.
Chris
UNUSED 10PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 10PCS...
RHINO DB150 LOT NUMBER 73 (A53084)
RHINO DB150 LOT...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
2015 ISUZU NPR 16FT BOX TRUCK (A54313)
2015 ISUZU NPR...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
