Comparison JINMA 854(4WD)
/ JINMA 854(4WD) #1
n4807g
Belarus 572, Farm Pro 8240
Hello....I have a FarmPro 824 that I purchased about 7 years ago. It runs fine, but as I get older, my left leg really dislikes the daily workout it gets clutching the tractor. Can anyone tell me if Foton, or Jimna makes an equivalent (HP, Cab) tractor with a shuttle shift system (hydrostatic if I'm using the correct lingo).
My left leg thanks you!
/ JINMA 854(4WD) #2
Shuttle shift and Hydro are not the same. Shuttle Shift still requiers the use of a Clutch every time you change direction or gear. All the Shuttle shift allows you to do is change direction gear wise without having to stop First. It's an improvement, but it's still shifting.
If you do a lot of FEL work, hydro is the only way to fly.
/ JINMA 854(4WD) #3
I would be surprised if Farmpro, Jinma and Foton all don't make a Hydro tractor in that HP range. I always thought Farmpro, Nortrac and about 5 other names were all just Jinma's.
/ JINMA 854(4WD) #4
can you guy help me with this ? I just got a farm pro 2420 ty290 my ? what oil goes back in the power steering and am I on the right track to check that fluid behind the seat sae30 is that what I need to put back in it. bec I got this from a friend he never checks anything I did a few things to it but I looked in the powersteering looked like its been dry for sometime the dip stick behind the seat has no fluid on it thanks for your time
/ JINMA 854(4WD) #7
That is where it goes, sorry I missed that part of your question. Also note that you check how full it is by just setting the dip stick down, do not screw it in to check.
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2017 Versatile 260 (A60462)
2017 Versatile 260...
2012 DIAMOND C  40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
2019 Ram 2500 4x4 Crew Cab Pickup Truck (A60352)
2019 Ram 2500 4x4...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
