Jinma 454
   / Jinma 454 #1
petar
Serbia
Jinma 454, IMT 539
Anybody have a wiring diagram for the Jinma 454, SL3105ABT engine ?
A lot of things don't work and i will try to fix them. Headlight switches are burned out, I'm hotwiring the headlights for now, indicators don't work, oil pressure gauge gets stuck on 10 as soon as I turn on the key and it goes back to normal when I start the engine ?! Nothing works on the tailights.
   / Jinma 454 #3
What year is your 454?
I have a 354 (2007), which shares a lot of components. The dashboard and switches are all a single module with a modular connector. I understand the earlier ones had more discrete components.
   / Jinma 454
It's 2008 year. I've managed to figure out most of the wiring using a multimeter. The problems are mostly in the fusebox. The turn signal flasher fell out, the wire gauge is tiny and some fuses are simply overloaded. A single fuse feeds the instrument cluster, the charging system AND the headlights !!!
The fuses fall out of the box and lose contact too easily. I'll be fitting an old mercedes W123 fusebox i have laying around from when i parted out one of those, that is far better quality than anything i can buy for these tractors.
Also most of the switches don't work. Some of the wires to taillights are damaged but I'll fix that easily. I'll also fit a 7 pin trailer light socket.
   / Jinma 454
Job almost finished. Everything except the brake lights works, the switch is broken and i need to get a new one. I also have to install a trailer light socket.
   / Jinma 454 #6
Dear guys, there is a copy of a Jinma wiring diagram in here somewhere but I cant find it. Anybody help. It has pin I,S,G and K on the Tach.
I was going to go to Staples an see if they could run off a readable copy. Any help trying to identify where these, and the sensor wires go
would be much appreciated. Thanks/Robert e-mail: spicerrb@hotmail.com
wire it up!
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A52748)
2004 Capacity Yard...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2019 Bobcat T590 Compact Track Loader Skid Steer (A51691)
2019 Bobcat T590...
2018 Infiniti QX60 Multipurpose Vehicle (A51694)
2018 Infiniti QX60...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
